05-13-2021 02:41 PM - edited 01-06-2022 02:03 AM
Hello,
I'm moving from Koodo to Public Mobile.
I've got the 821 error code in the process of activating the SIM card.
I need a moderator help.
Thanks,
Alex
05-13-2021 03:30 PM
https://chat.telus.com/chat/publicmobile/chat-pm.html
This is the link to dedicated activation assistance running during work hours
05-13-2021 03:00 PM
@alexsupr : And don't forget to use a referral code for a $10 credit that should appear within 3 days. If you didn't ask here or in private messaging for one and you got deluged by them un-asked for then those people broke the rules.
05-13-2021 02:56 PM
Wait 50 min. to clear your session lock time out. Then clear your browser. Reboot your device. Open one tab only in secret/incognito mode. Use firefox, chrome or safari as they work best.
Follow @dabr instructions if you are porting from koodo prepaid if its postpaid then include the following info:
Leave your koodo sim card in your phone and respond YES to the porting authorization text within 90 minutes of recieving it. Then place your pm sim card in your phone. Your port will complete within a few minutes to a maximum of two hours. Your koodo sim card will stop working and you will recieve incoming calling on you pm sim card. Welcome to public mobile!
05-13-2021 02:44 PM - edited 05-13-2021 03:04 PM
@alexsupr wrote:Hello,
Thanks,
Alex
@alexsupr Is your Koodo prepaid or postpaid?
Prepaid requires moderators assistance and a temporary number can be take at activation. Koodo postpaid transfer can also be done at activation and if this is the case, then clear your cache/cookies and use a new browser with incognito/privacy mode enabled before retrying. You may also be better of waiting another hour before retrying.
Edit: btw here's couple of links to contact moderators, if you are Koodo prepaid, who can be reached via chatbot and following prompts here: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If unable to submit a ticket with above link try sending a private message to Moderator_Team here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
