04-07-2022 06:16 PM
I am no longer able to receive incoming calls. Outgoing calls, text and data are all working.
When someone dials my number, the message is “5H1 (5B1 sometimes). This number is not equipped to receive incoming service.”
I have been an active client since 2020 and have not changed plans or sims recently.
Where can I find help to resolve this?
04-07-2022 07:07 PM
Thanks. My account is still active and nearly 3 weeks before my next bill. I will try a service ticket.
04-07-2022 06:55 PM - edited 04-07-2022 06:55 PM
@CChoy Glad that it is not the phone.
Again, account shows Active when you login My Account?
which area you are at? you check the Telus Status page for outage?
https://www.telus.com/en/nu/outages
If none work and no outage shown, I think it is time to contact PM Support and have them to check on the system side:
1. If you have access to My account: Click on the bubble on the lower right or https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
04-07-2022 06:47 PM
I think I can rule out a device issue. I’ve tested the PM Sim in another phone and still not able to receive incoming calls. Testing a Virgin sim in the original phone works fine.
I’ve tried calling using Rogers home phone, Virgin and Koodo. Same message about number not equipped for incoming calls.
04-07-2022 06:18 PM - edited 04-07-2022 06:19 PM
@CChoy First try to reseat the SIM, power off ,take the SIM out for a minute then put it back in and power up
If it still not works, try to change the Preferred Network type to 3G ONLY or WCDMA ONLY and see if it works
If you have another phone around, try to put your PM SIM there as well and see if you can get incoming calls on the other phone
Also, when making calls to yourself, make sure you ask friends with couple different service providers to try
