04-05-2023 08:50 PM
Hello, I'm trying to activate a new plan from Koodo. However, the activation appears with an error code. I checked my bank CC and payment went through. Can an agent please contact me? Thank you
04-05-2023 09:41 PM
@NadiiaMaloava use this direct link to open ticket with PM Support for porting request from Koodo Prepaid:
https://urlshortner.tiia.ai/Rqg6DB
04-05-2023 09:38 PM
Use the ticketing system for a faster response time. Click here to create a support ticket
04-05-2023 09:37 PM
@NadiiaMaloava wrote:Yeah, I noticed my Koodo sim card with my original phone number is still working fortunately! I've successfully activated the PM sim card with a new number. Is an agent available here to help me port my Koodo phone number to Public Mobile? Thanks!
From earlier, please use the provided instructions to use the chatbot to open a ticket.
04-05-2023 09:20 PM
04-05-2023 09:09 PM
@hTideGnow wrote:
HI @NadiiaMaloava activate from Koodo
do you mean you are activating PM and port from Koodo?
do you have Koodo prepaid or postpoaid?
if it is not Canadian number error, then maybe you are now Koodo Prepaid/?
if you are , you need to activate with a new number first, then submit ticket to CS agent for a porting after the line is activated
In this situation, the activation process already being completed but the customer saw something such an error 821 message. In such cases, the customer wouldn't be able to choose a phone number at this point. I suspect that some members may suggest calling the porting department, but I strongly advise against that. With thiese numbered errror codes during activaiton, provisioning of the Public Mobile service often doesn't happen properly or the Self Serve account doesn't get created properly. As a Public Mobile customer support agent would need to be contacted anyway, the mentioned SIMon chatbot ticketing method should be used. If a customer calls the porting department and has the number porting completed, there's a very likely chance that the customer will lose access to the phone number as the number could be transfered to a not-yet-working Public Mobile account.
04-05-2023 09:05 PM
@NadiiaMaloava wrote:Port from Koodo prepaid.
then please activate with a new number first.
After you activate and everything working, submit a ticket with PM agent and they will help to port from Koodo prepaid
04-05-2023 09:02 PM
Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request). Click the result which states Click here to submit a ticket and follow the prompts, or,
Send a private message to the Customer Support Agent by clicking here You’ll need to be logged into your Community account for the link to work.
04-05-2023 09:01 PM
04-05-2023 08:56 PM
