06-27-2023 04:36 PM
06-27-2023 05:30 PM
Great, easy to follow instr. thx
06-27-2023 05:17 PM
Such a great question. I LOATHE voicemail!
06-27-2023 04:40 PM
Check out this thread for further helpful details:
06-27-2023 04:40 PM
Use the extended absence greeting option which then lets you stop taking recordings. People will call in, you don't answer for some reason, it drops to voicemail, it plays your greeting - then it hangs up.
06-27-2023 04:39 PM
@jerry2020 no way to turn off
there used to be a workaround b8tne8th conditional forwarding not working now, that workaround is not working too
Please used extended absence instead
Follows this to create extended absence greeting and don't let caller to leave message:
[3]Greetings --> [4]Extended Absence --> [2]Record
[3]Greetings --> [4]Extended Absence --> [5]Message not allowed after greeting
[3]Greetings --> [4]Extended Absence --> [4]Turn On
06-27-2023 04:38 PM
You can't "cancel" voicemail.
You can ignore them, however.
