Cancel Add-on
maggiemak
I accidentally purchased (using reward points) an Add-on that I already had in my subscribed plan. Can I cancel it?
Thank you!
ABG11
If you havent used that add-on at all you can try submitting a ticket to support team. They might give you a balance instead of refunding you.
@maggiemak support agent likely can help to reverse the redemption
Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
TheSterlinger
Add per the fine print, Add-ONS are non refundable.  But, you can try your luck and use the chatbot to create a ticket and ask.
