Canadian data add-on
Oceanbluehusky
I have added funds to my account, but when I go into add ons, there’s no option to add Canadian data.  I’m all out of data and need to buy some more.
@Oceanbluehusky
Private mode is right
Click the arrow beside Bundle to shoe more options, click Data
@Oceanbluehusky
Private Mode is fine...
Hollister
@Oceanbluehusky
Click the Data tab. Default is Bundle…you need Data.
Oceanbluehusky
Thanks for the tip.  I tried logging in in Private Mode .  Is that what you mean?  I’m not sure what incognito mode is.  The only options for add ons that I get are U.S add ons.
hairbag1
@Oceanbluehusky
log in to your account using incognito mode / Plans and Add-ons. / Shop ADD-ONS / Data...then select one of the 2 In-Canada Data options.
@Oceanbluehusky try login again using Incognito mode.  or Private mode in Sarafi.  There is certainly data add-on there
