11-17-2018 12:37 PM - edited 01-05-2022 02:31 AM
11-17-2018 01:20 PM
@gp1953leb wrote:Thanks, but I have tried several numbers and I keep getting the same message saying I am not covered under my plan. When I check my plan it clearly states I have a Canada wide plan?
Okay. You account was not provisioned correctly. Try the stolen/lost phone trick suggested by @Anonymous to run the PM provisioning software again. Good luck.
11-17-2018 01:14 PM
Are you sure sure you haven't used all your minutes? 50 minutes can go by pretty fast. It's total in and out.
Try the lost/stolen feature.
Log in to self-serve. Plan & Add-Ons from top menu. Lost/Stolen Phone from next menu. Suspend Service button. Log out. Wait a few minutes. Log back in and back to Lost/Stolen Phone and Resume Service this time. Log out. Restart phone.
See what happens.
11-17-2018 01:07 PM
11-17-2018 12:59 PM
@gp1953leb wrote:I checked self-serve and it does confirm I have a 50 minute Canada wide plan and I haven’t used up all my minutes.
Try calling another long distance number to determine whether the problem is only for that number or your account provisiioning issue.
11-17-2018 12:49 PM
11-17-2018 12:46 PM
It’s not a new area code and it is with the province.
11-17-2018 12:43 PM - edited 11-17-2018 12:45 PM
@gp1953leb wrote:I have dialed 1 and no, the call will not connect.
Where are you trying to call? Is it a new area code? Have you logged into the self serve to make sure you have the correct plan?
11-17-2018 12:42 PM
11-17-2018 12:39 PM
@gp1953leb wrote:I have a 50 minute Canada wide plan, why can’t I complete a long distance call within Canada? Every time I try to call i get a message saying I need a long distance add-on!
Dial a 1 before long distance number.
Will your call connected if you ignore the long distance alert message?
11-17-2018 12:39 PM
Are you putting a 1 in front of the number you are trying to dial? Even with Canada wide calling you will need to dial it like it is a long distance call
