02-26-2024 08:17 AM
Can I call the US for free while in Canada with the Canada/US wide minutes or is it only if I’m in the US?
02-26-2024 12:46 PM
It's all very clear in the "details" section; read the footnotes.
02-26-2024 09:02 AM - edited 02-26-2024 09:04 AM
Hi JaniceH1
Please Check this post as it covers pretty much any question you have posted and may have...
https://productioncommunity.publicmobile.ca/t5/Get-Support/Clarification-34-50GB-5G-Canada-US-Plan-a...
02-26-2024 08:39 AM
So to sum up, I don’t want to switch until I confirm, I get free long distance to the US calling from Canada?
02-26-2024 08:35 AM
It’s from Canada so you can call to the US. If you have a Canada-US phone plan then you’re able to do both.
02-26-2024 08:35 AM
You can. All calls to the US and Canada are covered regardless of whether you are in the US or Canada.
