Canada and US Talk
10-08-2018 01:20 PM - edited 01-05-2022 02:04 AM
11-10-2019 04:16 PM - edited 11-10-2019 04:17 PM
@walmart3161 wrote:Yes that is correct. Also its a monthly pay plan that they do not add on to your bill. if your plan does not include it, it will not work.
I'm not sure which member you were answering, but this thread is more than a year old and the questions were answered long ago.
11-10-2019 01:44 PM
10-08-2018 01:44 PM
US Roaming Talk Add-Ons require a Talk plan. Calls made to numbers starting with the following six-digit combinations are not included in U.S. Roaming talk Add-Ons or U.S. calling from Canada and will not be completed when dialed: 712-432, 605-562, 641-552, 605-475, 605-477, 712-775, 559-726
10-08-2018 01:37 PM
@popping wrote:
@drmartin wrote:
@ShawnC13 wrote:
@johnny5 wrote:My plan is a new promotion. It says unlimited Canada and US talk. My question which I am sure I know
1) is the US talk for all calls made from Canada ?
2) I would not pay long distance if day I called anywhere in Canada to say Florida? Is that correct ?
That is correct so base plans are for calls generated in Canada. To make calls in the US you would need the US rising addon
Can you order it in advance (ie. pay today but have it start on Friday?) or do you need to order right before you cross the border?
US roaming add-on starts immediately. Therefore, buy it before leaving Canada. Remember buying add-on is a 2 steps process.
Thanks. 🙂
10-08-2018 01:33 PM - edited 10-08-2018 01:41 PM
Purchasing an Add-On? Be sure to:
1. Add funds to your account, if you don`t have sufficient funds
2. Go back to the Add-Ons page and select your Add-On.
10-08-2018 01:28 PM
@johnny5, there a few area codes in the US that will not work, as they are charged premium rates to connect. But otherwise, yes, should be as you expect.
10-08-2018 01:27 PM
10-08-2018 01:24 PM
