05-13-2017 12:16 AM - edited 01-05-2022 02:04 AM
I have a very serious issue with Public Mobile that may be a deal breaker. It's such a problem that I think I might switch to a carrier with $100 more a month because of it.
I am talking about the carrier name in the status bar.
It is so long and ugly that it is quite hard to bear. It is so long, in fact, that sometimes it doesn't even fit. Sometimes, you just get a "...". Public...
Public what? How am I supposed to know what the rest of my name is? My short-term memory can't handle it.
I would like this issue to be fixed. If this said PUBLIC or Public instead, it would be much less horrendous. You know, like every other carrier does (imagine if Telus used Telus Mobility in their carrier name!
06-21-2017 03:03 AM
Mine is ok . Ip 6sp
06-20-2017 11:22 AM - edited 06-20-2017 11:23 AM
Well, if the rumours turn out to be true, it seems like the next iPhone may not have as much space for a carrier name in the status bar at all...
https://www.macrumors.com/2017/06/19/leaked-iphone-8-screen-protector/
06-12-2017 05:38 PM
@texwood wrote:Note: in iOS 11 that was announced earlier this week, the bars will be returning instead of the circles.
Yeah, that should make it fit properly. I always hated the dots when they changed over. When I was still jailbreaking before iOS10, i would always use a tweak to get the bars back.
06-08-2017 03:22 PM - edited 06-08-2017 03:24 PM
@thighmaster69 wrote:
Your wish has been granted. Public Mobile has just changed their name to "Public..."
So now you should have no issue with the abbreviated carrier name on the status bar because now "Public..." in your status bar really means "Public..."
06-08-2017 01:39 PM
I liked the dots because they were different... but I didn't like the iPhone, and still don't.
06-08-2017 12:53 PM - edited 06-08-2017 03:35 PM
06-08-2017 12:47 PM
05-17-2017 03:31 PM
I love that there are still people replying to this as if it's a serious thread. 😛
05-17-2017 03:08 PM
05-15-2017 04:35 PM
lol, this is too funny!
05-15-2017 11:57 AM
Blame Jony Ive - iOS 6 and prior uses verical bars which displays the signal strength in the space of one or two dots. iOS 7 changes the design to these dots that take up all that space for no practical reason.
If you look at Apple vs Samsung court documents, the initial OS design from Ive resembles the dots as shown in iOS 7; look and feel changes related to iOS 7 didn't get implemented until Scott Forstall got sacked (due to the Apple Maps fiasco) and Ive took over.
05-15-2017 12:06 AM
speaking of cheeky tongue's ....
My Windows Phone displays an "L" only ( I think for LTE). When I swipe down from the top it then displays the full name "PublicMobile" so a plus for Windows Phone !
And let me get this straight.... thighmaster69 wants a shorter name ? 🙂
05-14-2017 09:16 PM
05-14-2017 04:54 PM
05-14-2017 01:15 PM
05-14-2017 01:13 PM
We should rename Pube for short. Anyone with me?
05-14-2017 09:29 AM
05-14-2017 12:31 AM
@xCameron94x wrote:they should all just buy an android, and skin it like iOs
Have you ever used a Chinese rom? They are all iOS copycats, no app drawer.
05-14-2017 12:26 AM
for my iphone it works fine
05-13-2017 05:56 PM
@srlawren wrote:@thighmaster69 clearly the best solution is to light your iPhone on fire* and then dissolve the cremated remains in acid. Then, go out and buy yourself an Android phone and live in much peace and happiness and enjoy the beatuiful, carrier-name free status bar you truly, truly deserve!
And if you really want to keep it but short, you can install custom ROM and have it as just PM 🙂
05-13-2017 04:33 PM
I dislike this too on my iPhone... However, this is partially Apple's fault too, because in the lock screen they have the fugly zoomed in status bar. When I used to jailbreak my iPhones in the past, there's a way to fix it with at tweak, and to change your carrier name or remove it completely. But the iOS10 jailbreaks have been weaksauce, so I haven't bothered.
05-13-2017 03:39 PM - edited 05-13-2017 03:44 PM
@srlawren wrote:@xCameron94x yeah been a loyal Nova Prime user for a few years now myself. Highly recommended, though there are lots of great choices.
You geeks just sent me googling now... What have I gotten myself into?
(Yes, that's tongue in cheek as well, and I use "geek" as a compliment! I'm learning something new every time I stop by!
05-13-2017 03:26 PM
05-13-2017 03:22 PM
when i had an android, i had nova prime. good thing its still attached too my google account!
05-13-2017 03:19 PM
@xCameron94x not that I endorse ruining* a perfectly good Android phone, but that's the beauty of Android in that you could do that if you want. Or skin it like, well, use your imagination and it's probably out there.
* I'm mostly being cheeky here, no actual disrepect is meant toward iFans. They actually are very nice, just not for me personally.
05-13-2017 03:17 PM
they should all just buy an android, and skin it like iOs ![]()
05-13-2017 03:14 PM - edited 05-13-2017 03:17 PM
@xCameron94x why would anyone ever buy a not-bent iP.....ah I guess I better not. 😉 EDIT: #bendgate
@thighmaster69 thanks for the accepting my solution 😉
05-13-2017 03:09 PM
patiently waiting for my phone to die, so i can join the good said again. AKA android. I dont think anyone will want to buy a bent iphone![]()
05-13-2017 03:09 PM
05-13-2017 03:06 PM - edited 05-13-2017 03:14 PM
EDIT: might I suggest a OnePlus 3T? 🙂
EDIT EDIT: forgot the asterisk: * don't really do this, please. or, at least use safety goggles. safety first.
