Canada USA plan
Yea123
I am driving to USA, how to use data in USA?
do i need to change any settings for making calls in Canada from USA?
I am currently using Canada USA plan.
UMM1
I was in Buffalo the other day, and also had to force T-Mobile – when set to automatic and I was on AT&T, I got no data.
Chalupa_Batman
Hey @Yea123
To use your phone down there, go into your network setting and turn off automatic and choose T-Mobile as I've found that to be the most reliable service there. Make sure your data roaming is turned on as well then reboot the phone. You should be up and running. If you don't know how to do this stuff, let me know and I'll post a tutorial for you. Just need to know what phone you have.
Usually, settings don't need to be changed.  On occasional, some customers have reported needing to manually force a connecto to either AT&T or T-Mobile for better service.  There are also no changes that need to be made to data settings other than  data roaming will need to be enable in the device's settings (it might already been turned on).
