03-04-2024 09:36 PM
03-05-2024 02:49 AM
Yes. But depends on how old your phone is. What is your phone model?
03-05-2024 12:01 AM
03-04-2024 10:01 PM
as far as I can tell, this plan is designed with "snowbirds" in mind. You'll be able to rec / send calls to most any US and Cdn numbers, text and use data just as you would at home. For best talk experience, confirm if your cell is VOLTE enabled by PM. While at home, disable wifi and make a local call. If the call stays on LTE , you're good to go. If it drops to 3G...well... not so good. The US has shut down their 3G for talk...so you'd need a VOLTE enabled phone OR a phone that will drop to 2G for calling.
03-04-2024 09:38 PM - edited 03-04-2024 09:39 PM
Sort of, @L_D
you might find that whether your device has VoLTE capability calling may be an issue in the USA unless you're device can switch down to 2G
When crossing the border you also need to turn on roaming and connect to T-Mobile or AT&T
