02-14-2026 11:38 PM
02-15-2026 12:57 AM
while in USA, you MUST have a cellphone that is VoLTE recognized in Public Mobile. Here's some reading with a device checker at the bottom of the article..
https://www.publicmobile.ca/en/get-help/articles/volte
Without VoLTE, your calls won't connect whilst in USA.
02-14-2026 11:51 PM - edited 02-15-2026 12:59 AM
@rcwoodguy1964
Yes, it will work in Hawaii. You’ll be roaming on one of the U.S. partner networks, such as T-Mobile, AT&T, or Verizon, depending on coverage in the area. Have a fun trip!
Just make sure data roaming is turned on. If for some reason calling, texting, or data isn’t working, try manually switching networks and testing each one. In my experience, T-Mobile tends to work best.
