02-05-2025 10:25 PM
I noticed this started yesterday and none of my setting changed, but I can't sent texts from Android to Apple. When I first joined PM I had this issue and it corrected itself.
02-06-2025 12:41 AM
Try rebooting your phone by powering off then back on.
If that didn’t work, try resetting the Network Setting on your phone.
02-05-2025 10:28 PM
Try turn of RCS from Google Message menu
Also, try different iPhone users
And try sending them MMS as well (make sure Mobile data is on)
And check the usage history on My Account and see if it recorded you sent that text. It could be a problem on the iPhone side
