Can’t sign in to my accnt
12-26-2022 10:11 PM
12-26-2022 10:54 PM - edited 12-26-2022 10:57 PM
@Maverick4 @Or you can follow @NDesai @link and reset your password make it easier
12-26-2022 10:52 PM - edited 12-26-2022 10:52 PM
Back out of pm close all your windows ,and do you see the 3 dots that @softech @mentioned
12-26-2022 10:50 PM
@Maverick4 you are using a web browser to post your question here
so, on the same web browser, click on the 3 dots, then select Incognito Tab (it might be called Private or InPrivate Tab), a new tab or window will be opened. Use that to launch My Account and see if it works
12-26-2022 10:47 PM
So how do I get the web browser on the phone whe I’m on pm
12-26-2022 10:37 PM
@Maverick4 @Your web browser is your search engine google / safari what you use to search the internet
12-26-2022 10:30 PM
@Maverick4 If you're unsure of your password, try resetting it here: https://myaccount.publicmobile.ca/en/forgot-password
12-26-2022 10:26 PM
@Maverick4 As My Account has some browser cache issue, using Incognito mode to login to My Account is a useful workaround.
Click on the 3 dots on the top right of your browser , select Incognito mode, or Private or InPrivate mode, to open a new browser window, then try to access My Account from there
12-26-2022 10:23 PM
@Maverick4 @Are you on iPhone or android , it’s your web browser
12-26-2022 10:19 PM
What the hell does clear your browser and try in cognitive mode
12-26-2022 10:18 PM
@Maverick4 , try and clear your web browser cache/cookies and try again in incognito mode / private mode
