02-09-2023 07:17 PM
Why in order to send a massage to some numbers I need my data on and for other numbers I can send massages without it?
I have the same issue with receiving massages.
02-09-2023 10:58 PM
just use Send as Text Message when it stuck for no mobile data
02-09-2023 07:58 PM
On iPhone:
Alternatively, when sending an iMessage to someone who doesn't subscribe to iMessage (or cannot receive at the time), hold on the recent iMessage you typed which will be blue in color, then tap the line item that reads "Send as a Text Message".
The message will then turn from blue to green indicating it is now being sent as a SMS message.
02-09-2023 07:38 PM
@Igor122 wrote:Yes I have an iPhone. Could you please advise me how to turn my iMassage off?
@Igor122 - you can leave iMessage on. Perform the following steps to try and fix the issue:
02-09-2023 07:31 PM - edited 02-09-2023 07:34 PM
Hi @Igor122 no need to turn off iMessage. You want to keep that option as your friends likely using iMessage
When you see the message not sent out, just click and hold the message bubble that you just sent. A menu with a few different methods will populate.
Select Send as Text Messag
02-09-2023 07:29 PM
02-09-2023 07:22 PM
Both iMessage and Chat Features require a wifi connection or data to send/receive texts.
Disable your Chat Features:
02-09-2023 07:21 PM
@Igor122 Go to phone settings / message and toggle off iMessage
02-09-2023 07:20 PM
02-09-2023 07:18 PM
@Igor122 If it’s a iPhone , try turning iMessage off
