Can't reset password
12-21-2017 02:47 PM - edited 01-04-2022 03:09 PM
Prior before being locked out, I went through the Forgot Password and entered all the details (email & security question). Once completed, it says an email will be sent to me, however, I have not received any emails.
My Account
12-21-2017 03:38 PM
@Acekiller wrote:Fixing the feature should be their new year resolution.
New years resolutions are meant to be broken, lol. Hopefully, they can commit to doing better than a new years resolution.
12-21-2017 03:20 PM
Agreed!
12-21-2017 03:12 PM
12-21-2017 02:57 PM
Hi @notasoloplayer,
Sorry to hear you're locked out. Unfortunately, the "forgot my password" feature has not been working properly.
So I'd recommend you to send a message to the Moderators with your account details and issue and they will be able to manually reset your password:
12-21-2017 02:57 PM
Once your account locked out only mod can fix it for you send a msg to mod
send msg add your pm number email address pin and detail msg
