Can't remember security question to reset password
Alexa1961
I had to make a new account to make this topic, but how can I reset my password? I don't remember how else I could've typed my answer
2 REPLIES 2
mimmo
@Alexa1961  are you talking about selfserve or about the community?they are different systems thus different logins.
the community only requires an emial to reset the password Self serve requires questions to answer.  to reset self serve if you dont remember the security questions then you will need to conatct mod as mentioned above.
Lieux
dID YOU TRY THE FORGET PASSWORD WITH NO SUCCESS? yOU WIL NEED HELP FROM THE MODERATOR HERE...https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 waiting time is few hours to 2 days but they work 7/7 days.
