Can't receive verification codes from Instagram
gb2k
I receive codes from other websites and apps.
For some reason, Instagram doesn't send me any verification codes.
I've rechecked my phone number, waited a few minutes to receive the code, and even tried it multiple times. It's the same issue where I don't get the code.
Is there any possible issue with the Cell carrier or Instagram blocking my number?
Thanks ❤️
2 REPLIES 2
gb2k
It's most likely an issue with Instagram, I'm not sure what you meant by PM Service though.
@gb2k
It sounds like an issue with instagram. Is your phone connected to PM service?
