07-02-2017 11:26 PM - edited 01-04-2022 02:16 PM
Hi,
I just ported from Freedom to Public, but currently am unable to receive any text or calls? Furthermore, I am not seeing the bonus 6GB of data on top of the selected 6GB plan?
Please advise, Thanks!
07-19-2018 03:25 PM - edited 07-19-2018 03:27 PM
Dear Moderator,
I need help pls. When someone calls me it says, my phone # is not assigned. I can't receive txts and calls. I got a $25 plan for 30 days with Public Mobile which covers unlimited canada wide- calls and texts and unlimited international texts, I just got this 3 days ago. I was thinking to do autopay if the service is good. Pls reply asap.
07-02-2017 11:41 PM
07-02-2017 11:38 PM
I got rid of the Regex problem! Fingers crossed for the current receiving text/call issue to be resolved within a few hours
Thanks for the kind assistance 🙂
07-02-2017 11:31 PM - edited 07-02-2017 11:33 PM
@lexhph wrote:Hi,
Please read the promotion post in the announces.
The 6 extra GB will follow 48-72 hours later. (Just give it time maybe a week or two)
Did you get rid of the regex problem ?
Porting from Freedom usually can take from 15 minutes to 3 hours, so give it time, the SIM cards will not be active immediatly, Once the porting is over you will receive a text from PM saying the porting is over.
For now keep using your old SIM until it stops. Hopefully it should go with no issues
Good luck 🙂
07-02-2017 11:29 PM - edited 07-02-2017 11:32 PM
