09-23-2020 12:23 PM - edited 01-05-2022 01:19 PM
I went in store to buy a sim card and activate my account, but the clerk could not port my number, even though my husband ported his number under the exact same conditions, and my current provider says there should be no problem with a port. The clerk suggested I get a moderator here to try. My plan expires in 3 days and I would rather not renew...
09-23-2020 07:09 PM
for the fastest response from customer support mods you need to use SIMon to create the ticket
click on the question mark chat bubble to the bottom right of your screen
type "port request"
(use the chat bubble options, then click "submit a ticket, click me" option)
*login using your community account
make sure to check your inbox(top right corner envelope icon) periodically, for a response
09-23-2020 01:30 PM
If you have the account number for the old phone number, then the in-store clerk should be able to port it over. Did the clerk give a reason why it won’t port over.
09-23-2020 01:10 PM
I had the same problem. A PM moderator advised me that my previous provider, Koodo, had applied port protection to my number. To save some time you may want to check with your old provider to see if that is the problem, and, if so, have them remove it. The moderator will not be able to port your number if port protection is in place.
09-23-2020 12:27 PM
@mojilife wrote:I went in store to buy a sim card and activate my account, but the clerk could not port my number, even though my husband ported his number under the exact same conditions, and my current provider says there should be no problem with a port. The clerk suggested I get a moderator here to try. My plan expires in 3 days and I would rather not renew...
Click this link and type in “port request” to be put in touch with a Moderator. Include the info from above.
09-23-2020 12:27 PM
Did you activate the sim card with a temporary number?
If yes.
Contact moderators. Open the chat bot by clicking the question mark on bottom right and type "Port Request" follow the prompts to open a ticket or send them a private message at this link.
If you didn't activate your sim yet. You can port during activation (there is a section) unless it's Koodo prepaid. If it's Koodo prepaid you open the account with a temporary number and follow instructions above to contact moderators to do the port.
