Can’t log it
Taeryn123
I cannot log into my account and I’ve tried changing the password and it says I’ve reached my max log in attempts
wisekal
Starting to think there is a technical problem. There are 2 other posts I've also found regarding the same issue. I also cannot log into certain accounts. Hopefully resolved soon.
Timer
@Taeryn123
close all browser or open from other machine then  Reset Password
after you reset password then use browser from computer,and clear cache and cookies and use one page inPrivate mode,
To Login Page
you will get verification code by email or SMS
and inserting the 6 digit number and not press anything
just wait a 5 second automatically be login,,
if still can't then contact support team by CS_Agent  to reset.
dabr
@Taeryn123   On your next login attempt, make sure to clear your browser cache/cookies and use privacy/incognito mode or another browser.
@Taeryn123
Try clearing your cache, cookie and go incognito on your browser then try login to your account.
hairbag1
Try again in about an hour.
Let us know if that works or not.
