06-06-2026 05:39 PM
I bought a new phone that only takes eSIMs. My current phone is eSIM compatible but I’m using a physical SIM card as I had issues trying to download the eSIM during my initial public Public Mobile activation. Now I’m stuck not able to download an eSIM on either phone. I keep getting an error message and saying to go look up my activation email, but that was years ago and I no longer have it. No idea how to get around this and download an eSIM.
06-07-2026 11:30 AM
HI @Travis_160
you don't actually need the QR code, the app tried to installed that for you
can you check your Settings , Cellular screen and confirm if the PM sim is there? if it is, then enable "Turn on this line" and set it with label Primary
if it is not there, then yes, you will need PM support agent to help. Use the link I provided above to message PM agent
06-07-2026 11:26 AM
I just get a generic “something went wrong” error message. Reading the support pages is what has led me to believe I need the QR code in my original activation email. But that didn’t work when I first joined either. I had troubles with downloading eSIM from the start and customer service’s solution was for me to buy a physical SIM. That’s no longer a solution now that new phones don’t support physical SIMs. I have no option to purchase a new eSIM on the app either. It’s like I’m stuck in this loop of needing to install this original eSIM that failed when I first activated. I sent a direct message to support, but still waiting for a response.
06-07-2026 08:53 AM
hi @Travis_160
can you post the screenshot of that error message about the activation email?
or you can ask PM support agent to help , you can submit ticket by direct message:
06-07-2026 01:57 AM
I can login to my account just fine. The issue I’m having is I can’t download an eSIM. I keep getting an error message that’s refers me to go check an activation email that I don’t have anymore.
06-06-2026 05:47 PM - edited 06-06-2026 05:53 PM
The email is just the login ID so it doesn’t matter if it is active or not. Just as long as the password is correct.
You need to contact a CS_Agent to help you login to your account to purchase and change from SIM to eSIM on the PM app.
