Can’t get text
sugahbearmomma
   I can send msg.  Make phone calls and receive them but I can not get any text msgs.    I did have the 10 day ya add on and I think it expired today
@sugahbearmomma wrote:
I can make calls.  Receive calls.  Send text.   But I can’t get any text back.   I did have a us 10 day ad on.
PM has known about this little glitch for a couple of years and have said they're looking into a fix...so far ...nada.
You can either wait until tomorrow and the problem will self-correct...or else follow previous instruction to contact a moderator. They might be able to fix it right away for you.
Good luck.
(duplicate threads merged)
It should correct itself by tomorrow. This is a known issue that PM has said they're addressing !
You can also click on the ? in lower right side of page to start process of moderator assistance.
@sugahbearmomma  - Yes, this issue should correct itself in 24 hours. Feel free to open a ticket in the hopes that a moderator might be able to fix this faster for you using https://publicmobile.ca.ada.support/chat/ . After opening that link, type in "rep".
sugahbearmomma
hairbag1
