10-20-2020 05:45 PM - edited 01-05-2022 03:49 PM
I have a iPhone 8 Plus. I followed directions for APN change but on my cellular network page all it says is apn then username and password. There is nowhere for the other codes it says to enter. I don’t know the username and password. How do I get the cellular data to work?
10-20-2020 09:37 PM
@Trac10 wrote:I have a iPhone 8 Plus. I followed directions for APN change but on my cellular network page all it says is apn then username and password. There is nowhere for the other codes it says to enter. I don’t know the username and password. How do I get the cellular data to work?
Try one or more of the below
Soft reset your iPhone 8 Plus that has no Internet access.
Restart Wi-Fi on your iPhone.
Turn Airplane Mode on and off.
Forget all saved Wi-Fi networks from your iPhone.
Reset network settings on your iPhone 8 Plus.
Erase your iPhone and restore default settings (factory reset).
Last resort: Restore your iPhone in recovery mode through iTunes.
10-20-2020 07:11 PM
@Trac10 leave your APN settings alone and reset your network settings
1. From the home screen navigate to Settings>General>Reset
2. Tap Reset Network Settings
If prompted enter your passcode
3. Tap Reset Network Settings
4. Restart your phone
10-20-2020 06:38 PM
1. Check your iPhone for update. If yes, update and restart your phone with PM SIM inserted.
2. You may need to connect to iTune app running in a PC to download PM carrier specific file to configure your APN file automatically. Make sure to restart phone after download or update.
Report result. Thanks
10-20-2020 06:34 PM
@Helpershelper just an FYI the APN's you provided are for Android phones not iPhone's.
10-20-2020 06:32 PM
@Trac10 if your APN says sp.mb.com change it to ISP.mb.com or vice versa. Save and reboot phone.
Let us know!
10-20-2020 06:04 PM
This is the definitive reading on APN stuff on an Apple product.
10-20-2020 05:54 PM - edited 10-21-2020 12:13 PM
10-20-2020 05:48 PM
The APN username and passwords should be blank.
10-20-2020 05:48 PM
@Trac10 hi have you tried to do a network reset?
