Can't figure out iPhone 3 MMS APN
09-26-2019 02:03 PM - edited 01-05-2022 07:17 AM
I am trying to configure my iPhone 3G (MC134C/A) to send and receive MMS.
I suspect the problem is the APN setting which I cannot find for MMS. The only one that appears is the one for data (which does work).
I have tried to use unlockit.co.nz which did not solve the problem.
The phone uses version 6.1.6 (10B500). Thanks to anyone who can help.
Phones
09-27-2019 07:52 PM
I have a mint shape iPhone SE for sale.
09-27-2019 07:43 PM
@Mango I can't believe you're trying to use a phone from 11 years ago!!
Is there no other phone you can try that is newer?
09-27-2019 10:32 AM
@BEER wrote:
@Mango wrote:I am trying to configure my iPhone 3G (MC134C/A) to send and receive MMS.
Connect it to iTunes and try re-setting as new.
The post above yours from the resident iphone expert says that the 3G can't do MMS without a whole lotta technical effort that mere mortals wouldn't generally want to attempt.
09-27-2019 10:22 AM
09-26-2019 08:52 PM
@srlawren wrote:I guess anyone affected can "thank" Apple for hard-coding MMS config on their earlier devices.
Well, old phones (3, 3G, 3Gs, and 4) are limited in the iOS version they can run (all version 7 and earlier), and it was in iOS 8 that Apple saw the light and switched to OTA-upgradable carrier profiles. Prior to that, only carriers that worked with (or paid?) Apple to get their APN embedded into the OS enjoyed "plug-n-play" compatiblity. The unlockit site is able to generate a profile that augments the build-in APN list, but it doesn't set the MMS APN (not sure if the file doesn't define this, or if it was just not included when the developers at unlockit made their tool).
I imagine an old but jailbroken iPhone could probably be configured to do MMS on Public, but that definitely goes beyond the capabilities of most users here, and not something I've ever had to dabble with.
09-26-2019 06:16 PM
Thanks @CalgaryBen, that was somethng I didn't realize. I guess anyone affected can "thank" Apple for hard-coding MMS config on their earlier devices.
09-26-2019 05:18 PM
Unfortunately, you won't be able to use MMS on your iPhone 3G with Public Mobile. It'll only be MMS capable on large/encumbant carriers (e.g. TELUS, etc.) because the MMS APN settings are hard-coded into the iOS, and the unlockit profile does not set this.
Essentially, the minimum iPhone is 4S if you want to be able to do MMS on Public Mobile.
09-26-2019 02:57 PM
I'm going to tag @CalgaryBen and link you to his posting on older iPhones, though I'm not sure if it will help with the 3 or not: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/FYI-iOS-and-APNs/m-p/323119/highlight.... Are you on the most recent version of iOS available to you?
09-26-2019 02:10 PM - edited 04-05-2020 12:04 AM
Stay Safe!
