Can't call out
06-06-2023
05:48 PM
06-07-2023
02:18 AM
computergeek541
06-06-2023 06:25 PM
Customer support did something on their end and now it works
06-06-2023 06:18 PM
@CandiceJaimie - before going to customer support (or while you wait for a reply), i'd like to know more details please... like what trouble shooting have you tried?
This message usually means a network issue, so is the issue on your end or the receivers end?
Is your account status Active in My Account or when you dial 611? If you are unable to dial 611 call 1-855-478-2542 or # 1-855-4PUBLIC from another device and see what the status says.
Do texts work? Does data work?
Try:
- restarting your phone
- toggle into then out of airplane mode
- perform a reset of the device's network settings
- Remove your SIM card, then gently reinsert it.
- If still issue, try your SIM into another phone to see if services work
Check for outages in your area:
https://www.telus.com/en/on/outages
06-06-2023 05:49 PM
Message support directly
- Or while your already here and logged in the community you can send a private message To CS_Agents click >>>here.<<<
