Can't activate services
Ryan58
Hello
I tried for several hours to transfer my number from rogers to Public without success. I have 2 lines I wanted to bring over but it wont work. The system says I need to speak to an agent to complete.
If someone can't assist I would appreciate it
1 REPLY 1
hi @Ryan58
try reboot the phone and login to app again and see if you can complete the subscription
and if you are activating eSIM, can you double check if the PM  eSIM is already showing up on your Sim Manager or Settings-> Ceulluar?
if yes, then you need to manually enable it and set it as Primary (please also remove old carrier sim card and disable old carrier esim)
but if you still cannot complete subscription or sim not there, ask PM support agent to help, you can submit  ticket by direct message:
