Can’t activate eSIM
Luckyboi
Hi, I purchased a plan with eSIM, but app says my phone isn’t compatible. iPhone XS Max and not from mainland China. Also did not receive eSIM activation email. App tells me to contact customer service agent and get refund.
Phil_Adelphus
@Luckyboi  You can contact customer service via the chat/message icon bottom right of this page.  If it gives you an error then send a private message to customer support via this link
You will need to check your inbox, envelope top right or tap your avatar for Messages if no envelope.
An agent may be able to get the esim working for you.
@Luckyboi
there is a chance that the error was there because the Public Mobile esim is already installed and just not properly enabled
On Android:  Check your Sim Card Manager and see if a Public Mobile eSim is there.  If so, make sure it is enabled.
On iPhone: check Settings > Celluar and see if the eSIM is there.  If it is, make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
And if the Public Mobile eSIM is there, disable or delete those non PM sim (eSIM/Physical sim).
If the non-PM sim is physical, remove it.  If the non-PM sim is an esim, disable using the SIM Manager on the phone (or set as Secondary and turn off "Turn on this line" for this non-PM esim)
Then reboot the phone and click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, open ticket with PM support using Chatbot:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗"
To discuss, please contact a Public Mobile customer support agent by opening a ticket using the chatbot:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
