03-13-2017 10:46 AM - edited 01-04-2022 01:35 PM
Hi,
Leaving for the states and wanted to add the US addon but the page has been in error all morning. https://selfserve.publicmobile.ca/error?aspxerrorpath=/Overview/plan-and-Add-ons/change-plan/
JF
04-16-2019 01:56 AM
@NJC wrote:I'm using Chrome under Win10 and had the same error trying to view my Add on page. Incognito didn't help but using Firefox did.
It's not just you, and it's not your browser. Tonight, self-serve has been showing blank/no plans in some of our accounts.
04-16-2019 01:54 AM
03-14-2017 09:50 PM
Okay, glad to hear it worked out. ![]()
03-14-2017 09:48 PM
I had to use MS Edge and the site worked.
The port was super quick, about 5 mins, then my old SIM no longer worked, and then a quick reboot of my new phone and everything seems to be ok.
03-14-2017 09:39 PM
Well, now that you've encountered an error, you should try the browser tips listed above.
Additional tips for porting:
-Use account number of old provider only as that is most reliable (not IMEI, ESN or PIN)
-Enter name and account number as it appears on your other provider's bill
-Alternate phone number is unnecessary and should be left blank
-Be sure to click checkbox "I am authorized to transfer this number" before filling in phone number
If none of that works, then you'll need to get a moderator's help. You should send one of them a private message with your current PM phone number, the phone number you're trying to port, the account number at the other provider, and the name authorized on that account. How to contact mods:
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Contacting-our-Community-Moderators/ta-...
Good luck and keep us updated as to how it goes.
03-14-2017 09:11 PM - edited 03-14-2017 09:34 PM
Having the same issue. I'm trying to port a number in via the "Plan and Add-ons" page as described in another thread and the page comes up with a Generic Error.
It is my first time browsing PM on this computer so there shouldn't be anything cached
EDIT: I had to use MS Edge, wasn't working in Chrome.
03-13-2017 02:40 PM - edited 03-13-2017 02:41 PM
03-13-2017 10:58 AM
Thanks, I was already in incognito and tried all you suggested. It seems to be available now.
Thanks for checking.
JF
03-13-2017 10:55 AM
03-13-2017 10:54 AM - edited 03-13-2017 10:56 AM
I just tried the page and it works for me.
If it still doesn't work for you, then here are some things to try:
-clear your browser cache
-use private/incognito browsing mode
-use a different browser
If none of that helps, then it's best to get a moderator to help with this, as you're short on time. Send them a private message with your phone number. How to contact mods:
