Can’t access add-on data
Claire_cost
I used my credits to purchase an extra gig of data. It’s showing up in my usage as available, but when I turn my LTE on I can’t seem to access it
time to ask PM to check and help
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA  code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.)    When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
Claire_cost
That didn’t work
@Claire_cost
To reset network settings on an iPhone, go to Settings -> General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings.
Claire_cost
I’m using an iPhone, there are no limits set and I don’t see a “reset network settings” option
slusagm
maybe your have mobile data limit enabled? check and make sure that is disable first
Then reboot the phone and Reset Network Settings and try again
