11-30-2022 08:10 PM
I created a ticket because I did not know the email on my account. Someone at customer service named Alex went over the process and gave me a new temporary password. That password didn't work. He told me to clear the cache and try again. I tried on 3 phones, my laptop and 3 different browsers and it doesn't work. Alex is telling me there's nothing more he can do.
It's been 3 hours, I just need access to my account so I can get my account number. Anyone else I can contact?
Thanks
My Account
11-30-2022 08:30 PM
Sounds like customer support is your best option - make sure to let them know of the "forbidden" messaging you're getting, @Karlis
- Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request). Click the result which states Click here to submit a ticket and follow the prompts, or,
- Send a private message to the Customer Support Agent by clicking here You’ll need to be logged into your Community account for the link to work.
11-30-2022 08:29 PM
I can't find it, I never accessed the account the email may have been typed wrong from day 1.
11-30-2022 08:27 PM - edited 11-30-2022 08:29 PM
If all you need is the account number, when you activated here, did you get a "Welcome to Public Mobile" e-mail?
If so, the account number is 'embedded' into the 'TO' field of that e-mail. It's the long number starting with a '1', followed by a bunch of zeros before a 6 or 7 digit number.
11-30-2022 08:25 PM
Unfortunately I think that's the only solution. Thank you for helping
11-30-2022 08:24 PM
Try submitting another ticket and explain your situation. Hopefully you will get an agent who is more helpful.
11-30-2022 08:23 PM
It's not, I even tried using a different device that doesn't belong to me and got the same message. Doesnt matter what device or browser I use it still won't work.
11-30-2022 08:21 PM
I tried on a completely separate device and it still doesn't work. Cache isn't the issue.
11-30-2022 08:20 PM
This may be a stretch, @Karlis , but when you log into self-serve, if your device has 'remembered' credentials, sometimes when they auto-fill they will automatically then try to login without tapping the sign-in button. (i know my mobile device/browser does this)
If you tap that button while the system is also trying to automatically log you in, it results in an error message.
Try again and note if that may be the issue.
11-30-2022 08:20 PM
Did all that, still get forbidden.
11-30-2022 08:18 PM - edited 11-30-2022 08:18 PM
11-30-2022 08:17 PM
They got my email sorted out and reset the password. When I try and log in using the info they gave me it won't work. I get "Forbidden". Their solution was to clear my cache and try a different browser. Nothing more they can do. I did all that but it still doesn't work.
11-30-2022 08:17 PM
Try clearing your browser cache and history. Close browser and then open a new window in incognito. Try chrome or edge browser.
11-30-2022 08:17 PM
@Karlis wrote:I created a ticket because I did not know the email on my account. Someone at customer service named Alex went over the process and gave me a new temporary password. That password didn't work. He told me to clear the cache and try again. I tried on 3 phones, my laptop and 3 different browsers and it doesn't work. Alex is telling me there's nothing more he can do.
Thanks
You need force to clear caches and cookies using ccleaner.
Close browser won't clear caches and cookies sometimes. Then using private or incognito mode to login.
11-30-2022 08:16 PM
I'm getting a blank page with "Forbidden" on the top. I just tried incognito and it didn't work either.
11-30-2022 08:13 PM
What exact error you got?
try to ask Alex to give me a new password, then use Incognito mode to login to My Account and it should work
11-30-2022 08:12 PM - edited 11-30-2022 08:13 PM
You mentioned you did not know the email on your account? How did this get resolved? Is it the email or password?
