10-05-2023 05:34 PM
Hello all. I've been told that this issue is a carrier issue. I have no way of accessing my Voicemail. The error message on my iPhone 11 shows as: "The operation couldn't be completed. (com.apple.mobilephone error 1034).
I reset my Network Settings. I can also get onto Voicemail by forcing it: Phone, keypad, press 1 until connecting to Voicemail. Nice to know I can get my messages, but I can't see if someone has left me a message or access it directly from my phone. Help! Thanks 🙂
Phones
10-16-2023 10:33 PM
I believe it's a new feature called live voicemail. I believe this is different from visual voicemail.
10-16-2023 09:16 PM
Just an update that CS agent did have to help with this situation. Mostly resolved, except for the fact that with the new iOS update, I cannot change the visual voicemail greeting to a personalized one. (When I press 1 on the keypad, it takes me to voicemail and I can hear my own greeting. However, on Public Mobile's visual voicemail, I cannot record over the generic computer greeting which is what people hear when they leave me a voicemail). I don't believe (can't see anywhere) that Public Mobile offers a visual voicemail. Not sure how to deal with this new issue now, but if I have any further updates will keep you all posted.
10-05-2023 05:59 PM
Did you look for that feature I mentioned? And the other idea mentioned of your OS version?
10-05-2023 05:50 PM
Thanks so much @hTideGnow. I have sent a request into CS. Will update here when I hear back from them. Cheers!
10-05-2023 05:49 PM
Yes, I should be able to see if there are any new Voicemails with the red dot on the phone icon. I also cannot even get onto Voicemail through Public at all. I'm sure the CS will reset it and it will be fine - we'll see 🙂
10-05-2023 05:41 PM
"Forcing it"? Isn't that the way to voicemail? Does your phone have that new live voicemail whatever it's called feature?
10-05-2023 05:38 PM
HI @JulieSB
But after Reset Network Settings, you can access voicemail by pressing 1 on the keypad? It is good
For notification, some people got problem, too. Usually this is resolved after iOS update
you can also submit ticket with CS agent and ask them to reset your voicemail
