09-04-2019 07:35 AM - edited 01-05-2022 06:51 AM
I have never had a data plan, after the recent granting of 1G free data to my plan I decided to check it out. I turned on the data slider in settings, but no dice. Data has been credited in my PM account.
Any ideas?
09-04-2019 08:31 AM
Awesome! Happy data surfing. Be careful, you'll be moving u to a $25 plan in no time. It's so convenient. Toggle your data off when you don't need it for data and MMS and make your 1GB last as long as you can. Good Luck!
09-04-2019 08:30 AM
Thanks, entered settings as per:
https://apn-canada.gishan.net/en/apn/public-mobile/sony-xperia-xz3
Restarted and I'm up and running 🙂
09-04-2019 07:56 AM
09-04-2019 07:51 AM
Try restarting your phone.
09-04-2019 07:50 AM
Restart you phone now that data is available. If that doesn't do it check your APN settings,
Try checking your APN Settings. These are mine:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
