Can't Text out on phone!
yox1923
I just installed the sim card on my Motorola Moto G7 PLAY phone.
I activated the SIM card on Dec. 10, 2019 but only installed it in the phone today.
I can phone out but I can't text to any other cell phone...Does anyone know what I need to do to text out?
Staliger
Can you also test SiM using another phone? If doesn't work, I can advise to seek for the moderator's help so that they could reset your account, and it may help: click the "?" in lower right side of the page, type "contact moderator", and follow directions.
Can you receive texts?
1. Enable data; restart phone.
2. Try checking your APN Settings.
For Android, click:
Settings > More / More Networks / Wireless & Networks > Mobile/Cellular Networks > Access Point Names >
These are mine:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
jaherne
Have you tried restarting your phone? It oftens helps to 'reset' things.
ChuckYeah
For Android, click:
These are mine:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
ChuckYeah
@yox1923 Is your data enabled?
Do you have the correct APN Settings?
For Android, click:
These are mine:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
