12-11-2019 05:22 PM - edited 01-05-2022 08:29 AM
1. Unlimited Canada calls
2. Unlimited US calls
Data and text not important, but welcomed if free or not impacting cost.
12-11-2019 05:30 PM
The only other plan you may consider would be the $25 unlimited calling plan plus the 400 minute Canada/us add on.
$40 total, but if you need more than 400 us minutes per month, the $50 plan is your safest bet.
12-11-2019 05:26 PM
@NavyKnight wrote:1. Unlimited Canada calls
There no longer is the plan builder here. The plans that you see are what is available and only the $50 plan has the US calling included
