Can receive texts and calls but can't send texts
ShemenLamuor
Where I'm able to locate my Message Center Number?
9 REPLIES 9
ShemenLamuor
BTW, I'm from Quebec & It works, so it same as Ontario no difference.
SIM-phony
Glad I could help!
ShemenLamuor
Thanks a lot, @SIM-phony & @LEGO Problem solved!
ShemenLamuor
Yes, there was the answer to my question:
@monster5000
Sorry. Wasn't sure what you meant originally.
The number I have is:
+16475800172
It's under the heading "Service center number".
LEGO
Go into you Messaging Settings.
I am from Ontario and I have +16475800172
SIM-phony
I beleive this thread addresses what @ShemenLamuor is looking for: Link
ShemenLamuor
The voicemail number I have, its fine.
My issue is with text message directly.
I mistakenly replace my Message Center Number & now I cannot receive or send text messages, I think its the same issue that @noel4140 had then.
The question is, where can I figure out my Message Center Number. Is it the same as the Voicemail number?
LEGO
Go into your Call Settings and look for Voicemail settings > Voicemail number.
NDesai
@ShemenLamuor You posted in an old thread, and so i moved it to a new one for better visibility.
Please elaborate on what exactly you are looking for and we will assist as best as we can.
