12-24-2023 02:42 AM
Greetings,
I am unable to change my address at Profile > Account Info > Edit
I have followed the exact format of the address on file ie. suite-street_number and postal code without space and various other combinations, always get 'Invalid Address'.
Someone mentioned that PM uses Google Maps API instead of Canada Post, so looked up my address on Google Maps and tried that particular format, same 'Invalid Address'. While I type in the street for example, I can see intermittently 3 dots underneath, as if something is checking or validating but there is no suggestion as to what has been found and/or suggestions so I suspect the API is not working/broken.
How exactly can I change my address? Do I need to contact CS for this?
Thanks
My Account
12-24-2023 04:53 AM
Thank you, that is correct, I received help through a private message from a user, very helpful, need to type in suite-street_no like ####-### (optional street name without ave/dr etc) and wait for the system to bring up what it has, then select from the list. Thanks!
12-24-2023 04:34 AM - edited 12-24-2023 05:02 AM
@G_Cristian wrote:I am unable to change my address at Profile > Account Info > Edit
To my knowledge, an address cannot be manually entered/typed in. It msut be selected from the list. Start typing your street number and street name and click the icon on the right to search for matching addresses.
12-24-2023 04:28 AM
@G_Cristian wrote:One more question, underneath the address there is a 'Alternate Phone Number' field currently has my existing PM phone number. What exactly is that used for? Thanks
It's not really used for anything. This is simply informaiton that Public Mobile has on file about you.
12-24-2023 02:44 AM
