CS_Agent
12-23-2023 09:04 PM
12-23-2023 11:40 PM
@BKNS27 wrote:Check to see if there are any outages in your area:
https://istheservicedowncanada.com/status/telus/map
This maybe the issue.
While a network outage is a possiblity, it wouldn't affect communications coming from certain people.
12-23-2023 10:10 PM
12-23-2023 09:29 PM
12-23-2023 09:15 PM - edited 12-23-2023 09:17 PM
@Mf11 Did you just join PM and try to port number in ? Did your reply YES to confirmation text from old provider ? I’ll send you porting team number private message . And they can re trigger the port request for you . If that’s not the issue and you need support here’s a direct link to them
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
12-23-2023 09:11 PM
Not receiving text and phone calls from certain people
