Can not activate cellular data network
bodil
Hi, new user and activated a sim card online for an iphone 4. Yes an iphone 4 🙂 Has a compatible IMEI number and can make calls. It shows public mobile 3G on my screen with full strength but when I try and use my data, it says (can not activate cellular data network). I checked my account and it has used some MB when I was in Cornwall. Now I'm temporarily in Toronto and data is not working?
Thank you
14 REPLIES 14
Eddy_G
Customer Support Agent
Also bodil,
iPhone equipped with iOS 8.1.1 to iOS 9.1
Cellular data:
APN - sp.mb.com
Username - Leave blank
Password - Leave blank
Visual Voicemail:
APN - sp.mb.com
MMS:
APN - sp.mb.com
MMSC:
http://aliasredirect.net/proxy/mb/mmsc
MMSC proxy - 74.49.0.18:80
MMS Max Message Size - Leave blank
MMS UA Prof URL  - Leave blank
Personal hotspot:
APN - isp.mb.com
Eddy
bodil
Thank you. this should suffice until my daughter gives me her iphone 7 🙂
sandpublic
Thank you
You can view your APN settings in one of the following locations:
Settings > Cellular > Cellular Data Options > Cellular Network
Settings > Mobile Data > Mobile Data Options > Mobile Data Network.
Make sure they are similar to the following:
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...
To revert to your carrier's default APN information, go to Settings > Cellular > Cellular Data Network > Reset Settings. If you installed a configuration profile, the profile's default information will be used instead.
CellGirl
Go to Settings > Cellular and tap the Cellular Data Switch to turn it off. Return to the home screen and wait 30 seconds. switch data back on. Enable LTE (Settings > Mobile> Mobile Data Options > Enable LTE) Connect your phone to a WiFi network and let the phone sit for about 30 seconds. Reboot phone.
@bodil
Eddy_G
Hi bodil,
Have you tried Reset Network Settings?
Settings > General > Reset > Reset Network Settings
In most cases it will fix it.
Eddy
PM Mod
smp99
Hi
Do you know how to check your APN Settings?
it should be     isp.mb.com
Settings->Cellualr->Cellular Data Network  - something similar
@CalgaryBen wrote:
@bodil wrote:
Yes an iphone 4 🙂
@bodil follow the procedure provided in this post.
If the amount of data used is around 5MB, then it may be the self-serve portal showing some "reserved" buffer data, which hasn't actually been used.
Took me to long to find the thread glad you are here @CalgaryBen
denis2
What plan are you on
ShawnC13
Thank you
@bodil, here is some great info for iPhone users posted by @CalgaryBen ,  https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/FYI-iOS-and-APNs/m-p/323118?collapse_...
Sharry19
@bodil Is there Cellular mobile data is active from your phone ?
Please restart your phone and check it again.
**** Please note: I am not a Moderator ****
bodil
Yes, cellualr data and 3G
Edit: the author themselves have you covered!
CalgaryBen
@bodil wrote:
Yes an iphone 4 🙂
denis2
Is the data turned on in your phone settings
