Can Receive MMS but not send
08-23-2019 01:40 PM - edited 01-05-2022 06:36 AM
Just within the last couple days, I've noticed that I can't text photos but can receive them. I checked my APN settings and still nothing!
Using a Samsung Galaxy S8+
Phones
08-23-2019 03:54 PM
@jadoiron Are you trying to send files too large? https://productioncommunity.publicmobile.ca/t5/Discussions/MMS-size-limit/m-p/167760#M51289
08-23-2019 02:20 PM
08-23-2019 02:15 PM
@jadoiron yea thats odd if those other suggestions dont work you may have to contact a moderator https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
08-23-2019 02:10 PM
Maybe try to reset your phone by clicking the lost your funtion, then click found the phone. if still not, may be send a private message to ask them to check.
08-23-2019 02:09 PM
@jadoiron wrote:
@RossN wrote:@jadoiron hi are you on the 10 dollar 50 outgoing texts? you may be out of them
No it's the $40 plan with lots of data and unlimited MMS / SMS messages.
Try turning your data off and back on and also airplane mode turn it on and off. Not sure why it would suddenly stop for you. Hopefully, someone will have more suggesions.
08-23-2019 02:06 PM
08-23-2019 01:46 PM
