08-20-2018 12:32 AM - edited 01-05-2022 12:35 AM
I sent messages to the Moderators for help. Then I find the solution. Can I withdraw the messages?
08-20-2018 08:30 AM
@abclilly, unfortunately once you send a message to the MODS it'll be in their queue and ca't be recalled or removed. When they get to your message they'll reach out to you, I suggest you just reply and let them know you no longer need their assistance so they can quickly move on to the next file.
08-20-2018 12:49 AM
@RobertQc wrote:@abclillyNo, since they read messages in the order they receive them even if you sent them a message asking them to cancel it, they will first try to solve your original issue. Depending on your issue you contacted them for and what you sent them I suggest waiting for them to get back to you then ignoring (if they request more info) or responding to that message saying you no longer need help
Hmm. T'wer it thus. Your post goes counter to the peculiar problem of dropping back down the queue when sending multiple PM's.
The ignoring or saying no longer needed would work though.
08-20-2018 12:42 AM
08-20-2018 12:41 AM
@RobertQc Thank you.
08-20-2018 12:34 AM - edited 08-20-2018 12:36 AM
