Can I use the Visual Voicemail feature in Android with PM?
emby
I recently purchased a Moto G7 Play and was prompted to setup the Visual Voicemail feature under the voicemail tab of the native android phone app. My PM voicemail is setup and operating properly but the Visual Voicemail feature is not. There is a notification at the top reading "Visual voicemail isn't working. Call voicemail to finish setting it up.
I attempted to navigate PM's voicemail settings with no success. Does the Visual Voicemail feature within Android work with PM? If so, any help to get it set up on my Moto G7 Play would be appreciated.
@emby
Posting here is the way to make suggestion. It probably won't happen. This is a value service.
emby
Thanks @gpixel. Would functionality like this be something that could be requested of PM? Is there a process in place where suggestions like this can be made?
gpixel
@emby I'm sorry, but PM doesn't support visual voicemail. when I first came to PM I asked about this same thing. I forgot which user told me, but there is a free visual voicemail app/website...
