03-18-2019 01:03 AM - edited 01-05-2022 03:46 AM
08-23-2019 02:27 PM
I have used Redmi Note 7 Pro for over 5months with PM (txt+call+data plan). No problem at all. I can apply 4G data plan but 3G is good enough for me.
For those who are waiting for Global version, no more Global ROM for MIUI10. I am guessing those Redmi Note7 with Global ROM might apply the lower version of MIUI?
Also, no more Redmi Note 8 but Redmi K20 Pro. This year Xiaomi decided to seperate the brand of XiaoMi cell and Redmi Note. Redmi Note is the one of the main competitor for Huawei Mate Pro
07-15-2019 05:05 PM
Rdmi note 7 is good to go onthe PM system. My friend has one on this system.
07-15-2019 05:01 PM
Yes, info in the link says it is an unlocked phone (not locked to a specific carrier)
07-14-2019 05:09 AM
Posting this as a public service.
03-25-2019 04:05 PM
Just wanted to add that there won't be a global model of the Note 7 Pro at all as per Xiaomi's announcement today.
The note 6 pro global band support is decent.
Hopefully the note 8 pro in the fall will bring a return to the global models. Strangely the Taiwanese models seem to support an additional band that some of the Canadian carriers use that the global model doesn't support (b2), but it shouldn't matter for most folks.
03-22-2019 07:29 AM
Hi , I am now using a MI A2 global version , works perfect , all chinChiphones should work fine as long as there the globsg version
03-18-2019 08:31 PM
awesome thanks!
03-18-2019 08:22 PM
@amansg wrote:
so anyone know if the phone in this link would be fine for public mobile
@amansg looks like yes
03-18-2019 08:07 PM - edited 03-18-2019 08:08 PM
03-18-2019 06:43 PM
@hzmy wrote:
@sandpublic wrote:Not true. The minimum it should support are as follows:
4G
B4 (1700/2100 AWS 1)
B12 (700)
B13 (700)
3G
B2 (1900)
B5 (850
B4 is required.
B12 B13 is optional.
B13 is never deployed by itself, so there's no reason to have it as a minimum requirement. B12 I agree with. It's the only band in some rural areas. The only other one would be B5, which is the main low band in some urban areas and would dramatically enhance indoor/underground coverage.
03-18-2019 05:42 PM
You think this would work?
Or would it be the same as the Redmi Note 7 one I sent earlier
03-18-2019 05:25 PM
Makes even more sense thanks, I'll look for the global version of this now
03-18-2019 05:09 PM - edited 03-18-2019 05:14 PM
In addition to what sandpublic said you could also check out the Redmi Note 6 Pro -- thats why you can't find the 5 pro that I have, it was replaced in the fall.
https://www.mi.com/global/redmi-note-6-pro/
Just be 100% sure it's the global variant. It will make your life much simplier than trying to unlock the bootloader and reflash a chinese variant to global spec. Avoid indian variants altogether for most of their phones as they usually have lower spec cameras.
03-18-2019 05:01 PM
If you can't wait for the Global version take a look at the Umidigi f1 or f1 play or if you want a better camera the Umidigi S3 Pro they are very well built phones run stock Android 9 are unlocked and support all the NA bands.
03-18-2019 04:48 PM
Ahh thank you, had no idea
03-18-2019 04:47 PM
@amansg wrote:isn't the version I linked the global version?
Official Global ROM means Chinese version flashed with Global ROM. Search for Global version in aliexpress instead.
03-18-2019 04:46 PM - edited 03-18-2019 04:48 PM
So if I get the redmi note 5 Pro, I'd have no issues whatsoever? Might just get that instead in that case. How about the original Redmi Note 5 global version? I can't seem to find the pro
03-18-2019 04:41 PM
03-18-2019 04:40 PM
But wouldn't 3g be fine?
03-18-2019 03:59 PM - edited 03-18-2019 04:01 PM
@hzmy wrote:
@sandpublic wrote:
@hzmy wrote:As long as you have band B4, which I believe it should, you can use public mobile.
4G
B12 (700)
B13 (700)
3G
B2 (1900)
B5 (850
B4 is required.
@hzmy @sandpublic strictly speaking, LTE in general is optional. As long as you've got the two bands of 3G, you can get talk, text, and HSPA+ data. That said, Band FOUR is the core LTE band, where as any others that PM supports (see here, from @sheytoon : https://productioncommunity.publicmobile.ca/t5/Discussions/LTE-network-fundamentals/m-p/134356#M5822... ) are optional and will get you extra LTE coverage in some areas of the country (some are for better urban coverage, some for rural, etc), but if you want LTE coverage, band 4 is the main one you want to look for.
EDIT: see here for even more detail: https://productioncommunity.publicmobile.ca/t5/Discussions/LTE-network-fundamentals/td-p/130581/page...
03-18-2019 03:36 PM
4G
B12 (700)
B13 (700)
3G
B2 (1900)
B5 (850
B4 is required.
03-18-2019 03:33 PM - edited 03-18-2019 03:37 PM
The current "global" 48+5mp models don't have B4 either FYI.
They're not meant for us.
Personally I'm also waiting for a Note 7 Pro and then I can give my RN5Pro to the Fiancee.
Not looking forward to being stuck with MIUI for another 30 days waiting for a bootloader unlock code then.
I love 3rd party AOSP based roms, what can I say?
03-18-2019 03:29 PM
4G
B12 (700)
B13 (700)
3G
B2 (1900)
B5 (850
03-18-2019 03:28 PM
@mik101 wrote:It does not have B4, I just checked.
Wait for a global variant.
Yes. Chinese version doesn't have B4.
I know aliexp has some global versions on sale.
03-18-2019 03:26 PM - edited 03-18-2019 03:28 PM
It does not have B4, I just checked. (And neither does the Chinese variant of the Note 5 Pro that I have -- but the global variant does). Once a global rom becomes available for that device they will be able to be reflashed (after unlocking the bootloader) but if someone on here has to ask, then they're not going to go to that trouble. Especially with Xiaomi increasing the bootloader unlock wait-time to around 30 days now.
03-18-2019 03:23 PM
03-18-2019 03:17 PM
I'd wait for the global variant of the Note 7 Pro.
My Redmi Note 5 Pro works fabulously (global model).
As always use a site like GSMArena to check the bands available on the device.
03-18-2019 09:19 AM
With so limited LTE support, do not buy unless very.cheap. Also won't resell very well if you upgrade later.
03-18-2019 01:09 AM
@amansg wrote:Here is a link to the phone:
According to gsmarena...barely LTE data. You could use it if there's a tower with that frequency. Otherwise voice and 3G (actual) data would be fine.
03-18-2019 01:05 AM - edited 03-18-2019 01:12 AM
No, it's missing B2 so I would not recommend it.
