12-08-2019 12:03 PM - edited 01-05-2022 08:25 AM
12-08-2019 01:45 PM
No you cant, you need to buy a PM sim card
12-08-2019 01:17 PM
hello if you have a Superstore close by they sell the sim card, then go home and activate and transfer your number
12-08-2019 01:08 PM - edited 12-08-2019 01:10 PM
Yes, the giveaways can be claimed up to and including Christmas Day. The only thing expiring today is the Dec 4 - 8 extra 1 Gb of permanent data added to $35+ plans. That is an additional 1Gb added to those plans every month, not the 1Gb of roll over data add-on that expires once it is consumed. It is designed to kick in if you use all your monthly plan data up a bit too soon. Any part of it not used rolls over to be available again in the future until you have used it all up.
AE_Collector
12-08-2019 01:00 PM
@AE_Collector wrote:Walmart can be a PITA to deal with but I don't believe there are any current bonuses that they would have any say over. Everyone gets the two Christmas bonuses and the permanent 1Gb data add-on for $35+ plans (thatvends today) iscspplied by PM. Biggest thing Walmart could mess up is your referral code but that is a rare problem and PM will fix it.
But ordering a SIM today isn't going to work for someone who is trying to grab the 1Gb permanent data bonus promotion that ends today. They need to get a card from a dealer today.
AE_Collector
Just to clarify though as I may have misunderstood this post here below about the giveaways
There it states that the giveaways will be available until December 25
12-08-2019 12:52 PM - edited 12-08-2019 01:05 PM
Walmart can be a PITA to deal with but I don't believe there are any current bonuses that they would have any say over. Everyone gets the two Christmas bonuses and the permanent 1Gb data add-on for $35+ plans (that ends today) is supplied by PM. Biggest thing Walmart could mess up is your referral code but that is a rare problem and PM will fix it.
AE_Collector
12-08-2019 12:30 PM
Hi
I just did the same you are trying to do....leave Bell for PM
You can't use the Bell sim
Easiest thing to do is order a $9.45 PM sim from Amazon. Then sim in hand wait for a bonus add on that you fancy and sign up
Walmart sells them as well, but pending your luck on a sales representative you could be led astray as they may not provide you your add on bonuses
Regards
James
12-08-2019 12:11 PM
No. You need a PM SIM card.
Telus owns PM and Koodo. PM does not let people to use Telus or Koodo SIM card. Forget about using the competitor Bell SIM card.
12-08-2019 12:05 PM
@waternlava you need a public mobile Sim card! You can get activated at Walmart, superstore mobile shop or London drugs or order a Sim card from public mobile site or Amazon
12-08-2019 12:04 PM
I don't think there are any providers that would let you use another providers' SIM. No/Yes. You need a PM SIM.
