08-24-2019 08:34 PM - edited 01-05-2022 08:40 AM
08-24-2019 09:42 PM
08-24-2019 08:42 PM
@weiqiw PM sim cards do not expire so it can be used provided that it hasn't been used (activated) in the past. It the sim was previously used then you will need to get a new sim card. If you are not sure then try activating it, if you get an Invalid SIM card error then you will need to get a new one.
08-24-2019 08:39 PM - edited 08-24-2019 08:40 PM
In addition to above, if it's from Public Mobile account that you already have and had not been suspended for 90 days and the phone number has not been ported out, you can keep using it by making the appropriate plan payment.
Otherwise, a sim card that has been used before cannot be reused.
08-24-2019 08:38 PM
if it hasn't been activated before
08-24-2019 08:36 PM
@weiqiwAs long as it hasn't been activated and it is a Public Mobile SIM card then you can use it.
