Can I get help to transfer a number from koodo?
savuaana
I have received a text from koodo asking me to confirm the departure from their services. I answered yes, and was disconnected. But public mobile did not transfer the number and asked me to take a new number which I did. Can I still have my koodo number transfered?
2 REPLIES 2
hi @savuaana
remove the Koodo sim or disable Koodo eSIM
put PM sim in, make sure it is enabled, and set as Primary.  Then Reboot phone and click Reset network settings and test
and check if the PM sim connected to the network.
if it does not connected to the network at all, it is not a porting issue but a problem with account. Ask PM support agent to help, you can submit  ticket by direct message:
Sansan
Yes, please reach out to cs agent for assistance.
Please be prepared to wait for a few hours for them to get to you.
