Can I change my referral code?
03-04-2024 06:27 PM - edited 03-04-2024 06:36 PM
My referral code is *RESTRICTED*. The zero and letter o sometimes are difficult to determine in different fonts. Even within the app they look completely identical. I would like to change it for a clearer determination when sharing it around. Thank you very much
Rewards
03-04-2024 06:56 PM
I was not saying to delete the post, just the code. But I thought you wanted to correct what you had typed not to get a new code all together.
03-04-2024 06:39 PM
Here's what I'd recommend, @Yoman
When sharing your referral code COPY it from your self-serve account to electronically send it to whomever is intending to use it.
Ask them to PASTE it into the referral code field.
If you're dealing with someone not as technically-capable, you might also want to manually help them with the activation, further ensuring your referral code is being applied correctly.
03-04-2024 06:36 PM
ok i changed it.
03-04-2024 06:35 PM
As far as I recall, no @Yoman , you cannot change your referral code.
Also, for the purpose of the Community terms of service, posting of referral codes is prohibited.
Please click the downward arrow upper right in your post, and edit out the referral code.
03-04-2024 06:34 PM - edited 03-04-2024 06:35 PM
why should i delete my post, and that chatbot was not the solution.
03-04-2024 06:29 PM
You cannot change it here. You have to use the link below to change. Please go back and edit your post by clicking on the circle with the download arrow to delete.
