Calls
10-26-2021 05:39 PM - edited 01-04-2022 05:20 AM
10-26-2021 06:04 PM
@jjlegge wrote:I can’t receive incoming calls
If you just ported your phone number from another cell provider it could take a few hours to complete the port.
Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
Make sure you do not cancel your previous provider's services.
Incoming calls are usually the last to port over.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
Leave the OLD provider SIM card in your phone to accept the PORT via SMS/text.
If you missed this 90 minute window, submit a ticket via this link to re-initiate the port:
Link to contact Customer Support Agents (CSA) for porting to Public Mobile
NOTE:
If you ported from a landline it could take up to 7 days to complete.
10-26-2021 05:47 PM - edited 10-26-2021 05:52 PM
10-26-2021 05:43 PM
Try rebooting your phone. If you have another phone then try swapping the sim. If you are still having problems then try a network reset.
10-26-2021 05:42 PM
