04-14-2022 11:51 AM
Hi ive been using public mobile for 3 years & the calls recently keep dropping. when i dial out a number the calls drop or it says ‘user busy’ & hangs up it wont even ring
heres an example below
04-14-2022 12:51 PM
Any issues with incoming or outgoing texts and data?
04-14-2022 12:09 PM
3G for the telephone network?
04-14-2022 12:08 PM
I'm in Ottawa, same problem here, both I and my friend use Telus
04-14-2022 12:01 PM
I dial many numbers everyday and the same issue happens with various numbers, i am located in Toronto.
04-14-2022 11:55 AM
@Goodlife062404 Are you in Sherbrooke, Quebec? there is active outage there:
https://www.telus.com/en/on/outages
04-14-2022 11:54 AM
@Goodlife062404 Did you try calling another number to make sure outgoing calls are working?
which city you are at?
Try to change the network setting to 3G ONLY
Also, try to reboot your phone first.
still not work, then try to reseat your sim
